Zum Hauptinhalt wechseln
Dell Inspiron 15 3567 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15 3567 Hard Drive Replacement, Open the Latch: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch and disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 3567 Hard Drive Replacement, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Dell Inspiron 15 3567 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly off the palm-rest assembly.
  4. Dell Inspiron 15 3567 Hard Drive Replacement, Disconnect the Interposer: Schritt 4, Bild 1 von 1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 3567 Hard Drive Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 3567 Hard Drive Replacement, Lifting the Hard Drive: Schritt 6, Bild 1 von 1
    • Lift the hard drive off the hard-drive bracket.
  7. Dell Inspiron 15 3567 Hard Drive Replacement, Align the Screw Holes: Schritt 7, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 15 3567 Hard Drive Replacement, Replace the Screws: Schritt 8, Bild 1 von 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 3567 Hard Drive Replacement, Connect the Interposer: Schritt 9, Bild 1 von 1
    • Connect the interposer to the hard drive.
  10. Dell Inspiron 15 3567 Hard Drive Replacement, Placing the Hard-Drive Assembly: Schritt 10, Bild 1 von 1
    • Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  11. Dell Inspiron 15 3567 Hard Drive Replacement, Replace the Screws: Schritt 11, Bild 1 von 1
    • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  12. Dell Inspiron 15 3567 Hard Drive Replacement, Sliding the Hard Drive Cable: Schritt 12, Bild 1 von 1
    • Slide the hard-drive cable into its connector on the system board and close the latch to secure the cable.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
Terrence15
79.555 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
5 Kommentare
My Dell Inspiron 15 3567 has a bottom cover which I STRONGLY suggest be removed after REMOVING THE BATTERY.
IMHO Those are important steps - their omission makes me lose any credibility for your site.
[deleted] - Antwort
The steps that need to be PRIOR to this guide are to remove the keyboard first, disconnect the keyboard cable, remove the 5 screws under the keyboard attaching the plastic to the motherboard. Then turn over the laptop, remove some 12 screws or so, remove the battery, remove the DVD drive, then separate the bottom case from the rest of the laptop carefully.
Thomas Dillon - Antwort
This guide is utterly useless and it neglects all the steps to get the actual bottom cover off to access the hard drive assembly. Zero stars.
pamadeus - Antwort
This guide is totally incomplete. It doesn't show how to access the drive in the first place. This guide should be taken down.
DarkAthena - Antwort
This guide is useless. I condemn the author for posting such an incomplete guide.
Scyth3934 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 54
Insgesamt: 12,312
