Zum Hauptinhalt wechseln
Dell Inspiron 15 3568 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15 3568 Display Assembly Replacement, Open the Display: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 15 3568 Display Assembly Replacement, Note the Antenna Cable: Schritt 2, Bild 1 von 1
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Cable: Schritt 3, Bild 1 von 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the display hinges to the computer base.
  5. Dell Inspiron 15 3568 Display Assembly Replacement, Lifting the Display Assembly: Schritt 5, Bild 1 von 1
    • Carefully lift the display assembly off the computer base.
  6. Dell Inspiron 15 3568 Display Assembly Replacement, Align the Screw Holes: Schritt 6, Bild 1 von 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  7. Dell Inspiron 15 3568 Display Assembly Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the screws that secure the display hinges to the computer base.
  8. Dell Inspiron 15 3568 Display Assembly Replacement, Route the Display Cable: Schritt 8, Bild 1 von 1
    • Route the display cable through its routing guides on the computer base.
  9. Dell Inspiron 15 3568 Display Assembly Replacement, Routing the Antenna Cables: Schritt 9, Bild 1 von 1
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
Ziellinie
Terrence15
79.131 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 558
