Einleitung
In this guide, we will show you how to remove and replace the Hard Drive.
Was du brauchst
Remove the screws that secure the hard-drive assembly to the computer base.
Lift the latch and disconnect the hard-drive cable from the system board.
Lift the hard-drive assembly off the computer base.
Remove the screws that secure the hard-drive bracket to the hard drive and lift the hard-drive bracket off the hard drive.
Place the hard-drive bracket over the NEW hard drive and align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Slide the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Slide the hard-drive cable into its connector and close the latch to secure the cable.
Replace the screws that secure the hard-drive assembly to the computer base.
