Zum Hauptinhalt wechseln
Dell Inspiron 15 5502 Case Removal
Was du brauchst
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
  1. Dell Inspiron 15 5502 Case Removal, Screws: Schritt 2, Bild 1 von 1
    • In the back there are 9 screws.
    • (captive) M2x7.5
    • M2x4
    • Unscrew these and store in a safe place. (eg: nescafe cup, container )
  2. Dell Inspiron 15 5502 Case Removal, Getting the base cover out: Schritt 3, Bild 1 von 1
    • Using a plastic scribe, pry the base cover starting from the recess at the display hinge and work your way around the sides to remove the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Dell Inspiron 15 5502 Case Removal, Battery disconecting: Schritt 5, Bild 1 von 2 Dell Inspiron 15 5502 Case Removal, Battery disconecting: Schritt 5, Bild 2 von 2
    • The sticker and the cable connector(below the sticker)
    • Peel the tape and disconnect the battery cable from the system board.
  4. Dell Inspiron 15 5502 Case Removal, Drain the power: Schritt 6, Bild 1 von 1
    • Press and hold the power button for five seconds to ground the computer and drain the flea power.
Abschluss
If you were following another article and was said to follow this guide, now you can go and follow it/continue in the step you stopped!
Android Alliance Mitglied von Android Alliance
Community
83 Mitglieder
670 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 43
Insgesamt: 986
