Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Lift the latch and using the pull tab disconnect the hard-drive cable from the system board.
Remove the four screws (M2.5x8) that secure the hard-drive assembly to the computer base.
Lift the hard-drive assembly out of the computer base using the hard-drive pull tab.
Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Lift the hard-drive bracket out of the hard drive.
Place the hard-drive bracket on the NEW hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Replace the four screws (M2.5x8) that secure the hard-drive assembly to the computer base.
Slide the hard-drive cable into the connector and press down on the latch to secure the cable to the system board.
Eine weitere Person hat diese Anleitung absolviert.
