Zum Hauptinhalt wechseln
Dell Inspiron 15 5576 Gaming Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Disconnecting the Display Cable: Schritt 2, Bild 1 von 1
    • Using the pull tab, disconnect the display cable from the system board.
  2. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Note the Display Cable: Schritt 3, Bild 1 von 1
    • Note the display-cable routing and remove the cable from the routing guides on the computer base.
  3. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Disconnecting the Antenna Cables: Schritt 4, Bild 1 von 1
    • Disconnect the antenna cables from the wireless card.
  4. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Note the Antenna Cable Routing: Schritt 5, Bild 1 von 1
    • Note the antenna-cable routing and remove the antenna cables from the routing guides on the computer base.
  5. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Sliding the Display Cable: Schritt 6, Bild 1 von 1
    • Slide the display cable and antenna cables through the slots on the computer base.
  6. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Remove the Screws: Schritt 7, Bild 1 von 1
    • Remove the four screws (M2x5) that secure the display assembly to the computer base.
  7. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Lifting the Display Assembly: Schritt 8, Bild 1 von 1
    • Lift the display assembly off the computer base.
  8. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Align the Screw Holes: Schritt 9, Bild 1 von 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the four screws (M2x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Sliding the Display Cable: Schritt 11, Bild 1 von 1
    • Slide the display cable and antenna cables through the slot on the computer base.
  11. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Route the Display Cable: Schritt 12, Bild 1 von 1
    • Close the display and turn the computer over.
    • Route the display cable and antenna cables through the routing guides on the computer base.
  12. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Connect the Antenna Cables: Schritt 13, Bild 1 von 1
    • Connect the antenna cables to the wireless card.
  13. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Connecting the Display Cable: Schritt 14, Bild 1 von 1
    • Connect the display cable to the system board.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 657
