Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Was du brauchst
Close the display and turn the computer over.
Using the pull tab, disconnect the display cable from the system board.
Note the display-cable routing and remove the cable from the routing guides on the computer base.
Disconnect the antenna cables from the wireless card.
Note the antenna-cable routing and remove the antenna cables from the routing guides on the computer base.
Slide the display cable and antenna cables through the slots on the computer base.
Remove the four screws (M2x5) that secure the display assembly to the computer base.
Align the screw holes on the NEW display assembly with the screw holes on the computer base.
Replace the four screws (M2x5) that secure the display assembly to the computer base.
Slide the display cable and antenna cables through the slot on the computer base.
Route the display cable and antenna cables through the routing guides on the computer base.
Connect the antenna cables to the wireless card.
Connect the display cable to the system board.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Note: This is a guide for replacing the entire display assembly, NOT just the display. If you are attempting to remove the display (like I was), gently snap off the display bezel, remove the four screws holding in the display, disconnect the display cable, connect the new display, screw it back in, and snap the display bezel back into place. Opening the bottom of the machine isn’t necessary.
