Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Using the pull-tab, disconnect the hard-drive cable from the system board.
Remove the four screws (M2x5) that secure the hard-drive assembly to the computer base.
Lift the hard-drive assembly, along with its cable, off the computer base.
Disconnect the interposer from the hard-drive assembly.
Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Remove the hard-drive bracket off the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Replace the four screws (M2x5) that secure the hard-drive assembly to the computer base.
Connect the hard-drive cable to the connector on the system board.
Eine weitere Person hat diese Anleitung absolviert.
