Zum Hauptinhalt wechseln
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
Was du brauchst
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: Schritt 1, Bild 1 von 1
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: Schritt 3, Bild 1 von 1
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
Abschluss
[deleted]
346 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 739
