Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Using the pull tab, disconnect the hard-drive cable from the system board.
Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
Note the hard-drive cable routing and remove the cable from the routing guides.
Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
Disconnect the interposer from the hard-drive assembly.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
Route the hard-drive cable through the routing guides on the palm rest and keyboard assembly.
Connect the hard-drive cable to the system board.
Adhere the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
