Zum Hauptinhalt wechseln
Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Turn the Computer Over: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and open the display to 180-degree angle.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  2. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Placing the Computer: Schritt 2, Bild 1 von 1
    • Place the computer on a flat surface with the display facing down.
  3. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Remove the Screws: Schritt 3, Bild 1 von 1
    • Remove the two screws (M2.5x7) that secure the display assembly to the palm rest and keyboard assembly.
  4. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Remove the Antenna Cables: Schritt 4, Bild 1 von 1
    • Remove the antenna cables from the routing guide on the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Lifting the Display Assembly: Schritt 5, Bild 1 von 1
    • Lift the display assembly off the palm rest and keyboard assembly.
  6. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Align the Screw Holes: Schritt 6, Bild 1 von 1
    • With the display facing down, align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the two screws (M2.5x7) that secure the display assembly to the palm rest and keyboard assembly.
  8. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Turn the Computer Over: Schritt 8, Bild 1 von 1
    • Turn the computer over and close the display.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Terrence15
79.309 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.984 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 1,803
