Zum Hauptinhalt wechseln
Dell Inspiron 15 5584 Battery Replacement
Was du brauchst
  1. Dell Inspiron 15 5584 Battery Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 15 5584 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 15 5584 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 15 5584 Battery Replacement: Schritt 3, Bild 2 von 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15 5584 Battery Replacement: Schritt 4, Bild 2 von 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Battery Replacement, Battery: Schritt 5, Bild 1 von 2 Dell Inspiron 15 5584 Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 Battery Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 15 5584 Battery Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 15 5584 Battery Replacement: Schritt 6, Bild 3 von 3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sam Vorn
977 Reputation
9 Anleitungen geschrieben
UMass Dartmouth, Team 1-1, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 1-1, Mellen Spring 2022
UMASSD-MELLEN-S22S1G1
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
I used this guide for a Dell Inspiron 5579 and it was close enough. The 5579 is larger. There were 10 screws instead of 9, and the back corner screws were removable. For the battery there were only the 2 left screws to remove as the 2 right battery mounts were also case-mounting screws. Was easy peazy. Now just need to charge it! Thanks!
John Highet - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 59
Insgesamt: 2,991
