Einleitung
Use this guide for assistance in replacing the battery in your Dell Inspiron 15 5584.
The battery acts as the power supply for all components of the laptop. Without a battery, the laptop will not function. An old or damaged battery may not hold as much charge as it previously had, and can also possibly not provide enough charge to other components of the device.
Before tampering with your device, make sure to drain the battery and turn off your laptop. Working with live electricity is a fire hazard and can cause injury/damage to electrical components. Furthermore, ensure the laptop is not plugged into any external power sources prior to starting this removal.
Was du brauchst
Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
Loosen the two captive back corner screws using a Phillips #0 screwdriver.
Slide an iFixit opening tool underneath the right side USB port and the keyboard.
Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
Gently pry off the bottom cover from the laptop.
Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
Detach the motherboard connector tab from the top left of the battery.
Remove the battery from the device.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
I used this guide for a Dell Inspiron 5579 and it was close enough. The 5579 is larger. There were 10 screws instead of 9, and the back corner screws were removable. For the battery there were only the 2 left screws to remove as the 2 right battery mounts were also case-mounting screws. Was easy peazy. Now just need to charge it! Thanks!
