Einleitung
In this guide, we will be showing you how to remove and replace the Battery.
Was du brauchst
Disconnect the battery cable from the system board.
Open the latch and disconnect the hard-drive cable from the system board.
Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
Press and hold the power button for five seconds to ground the system board.
Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
Slide the hard-drive cable into the connector on the system board and close the latch to secure the cable.
Adhere the tape that secures the hard-drive cable to the battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
