Zum Hauptinhalt wechseln
Dell Inspiron 15 7560 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15 7560 Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  2. Dell Inspiron 15 7560 Hard Drive Replacement, Lifting the Hard Drive: Schritt 2, Bild 1 von 1
    • Lift the hard-drive assembly off the palm rest and keyboard assembly.
  3. Dell Inspiron 15 7560 Hard Drive Replacement, Disconnect the Interposer: Schritt 3, Bild 1 von 1
    • Disconnect the interposer from the hard-drive assembly.
  4. Dell Inspiron 15 7560 Hard Drive Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15 7560 Hard Drive Replacement, Lifting the Hard Drive Bracket: Schritt 5, Bild 1 von 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15 7560 Hard Drive Replacement, Align the Screw Holes: Schritt 6, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15 7560 Hard Drive Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 7560 Hard Drive Replacement, Connect the Interposer: Schritt 8, Bild 1 von 1
    • Connect the interposer to the hard-drive assembly.
  9. Dell Inspiron 15 7560 Hard Drive Replacement, Align the Screw Holes: Schritt 9, Bild 1 von 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  10. Dell Inspiron 15 7560 Hard Drive Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Terrence15
79.555 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
Ein Kommentar
is the hard drive where the os is installed or in the m.2 drive and can i use a wd blue 512gb 3d nand ssd
Ethan Abraham - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 1,154
