Einleitung
In this guide, we will be showing you how to remove and replace the Battery.
Was du brauchst
Disconnect the battery cable from the system board.
Remove the screws that secure the battery to the palm-rest assembly.
Lift the battery along with the battery cable off the palm-rest assembly.
Press and hold the power button for 5 seconds to ground the system board.
Align the screw holes on the NEW battery with the screw holes on the palm-rest assembly.
Replace the screws that secure the battery to the palm-rest assembly.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
