Zum Hauptinhalt wechseln
Einleitung
This guide will lead you through the process of removing the back panel of the Dell Inspiron 15 7579 to access the internal components.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the ten 7.9 mm screws with the Phillips #1 screwdriver.
    • Remove the ten 7.9 mm screws with the Phillips #1 screwdriver.
  2. Insert metal spudger into a gap in between the back panel and the back of the screen. Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
Abschluss
Inaki Madrigal
715 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S24-G9, Maness Spring 2018 Mitglied von Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 9
Insgesamt: 767
