Einleitung
Upgraded RAM can help your computer run smoother. Be cautious when following guide backwards.
Was du brauchst
Insert metal spudger into a gap in between the back panel and the back of the screen.
Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
Fold the plastic flap over on the other side.
As before, pull the fasteners away from the chip with the tweezers.
Remove the chip by carefully pulling it out with the tweezers.
