Einleitung
In this guide, we will be showing you how to remove and replace the Battery.
Was du brauchst
Remove the battery cable from the routing guide on the computer base.
Remove the five screws (M2x4 T8) that secure the battery to the computer base.
Turn the computer over, open the display, and press and hold the power button for five seconds to ground the system board.
Slide the battery in the slot on the computer base and align the screw holes on the battery with the screw holes on the computer base.
Replace the five screws (M2x4 T8) that secure the battery to the computer base.
Route the battery cable through the routing guides on the computer base.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Dell UK do not sell a genuine battery replacement (part 71JF4). Where can a battery be purchased that will work, without running into the issue stated on the Dell forum that non-Dell batteries are not recognised and will not charge? Replacement batteries shown on Amazon and eBay provide no certainty that they are genuine or would otherwise work. Thanks!
