Zum Hauptinhalt wechseln
Dell Inspiron 15 Gaming 7567 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Disconnect the Camera Cable: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Peeling the Camera Cable: Schritt 2, Bild 1 von 1
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Note the Routing: Schritt 3, Bild 1 von 1
    • Note the antenna cables routing and remove the antenna cables from the routing guides on the computer base.
  4. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Screw: Schritt 4, Bild 1 von 1
    • Remove the screw (M3x3) that secures the display-cable bracket to the system board.
  5. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Lifting the Display Cable: Schritt 5, Bild 1 von 1
    • Lift the display-cable bracket off the computer base.
  6. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Disconnecting the Display Cable: Schritt 6, Bild 1 von 1
    • Using the pull tab, disconnect the display cable from the system board.
  7. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Display Cable: Schritt 7, Bild 1 von 1
    • Remove the display cable from the routing guides on the computer base and peel off the display cable from the computer base.
  8. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Screws: Schritt 8, Bild 1 von 1
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  9. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Screws: Schritt 9, Bild 1 von 1
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Open the Display: Schritt 10, Bild 1 von 1
    • Turn the computer over and open the display.
  11. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Screws: Schritt 11, Bild 1 von 1
  12. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Lifting the Display Assembly: Schritt 12, Bild 1 von 1
    • Lift the display assembly off the computer base.
  13. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Align the Screw Holes: Schritt 13, Bild 1 von 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  14. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Replace the Screws: Schritt 14, Bild 1 von 1
    • Replace the two screws (M2x2.5) that secure the display assembly to the computer base.
  15. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Close the Display: Schritt 15, Bild 1 von 1
    • Close the display and turn the computer over.
  16. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Replace the Screws: Schritt 16, Bild 1 von 1
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  17. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Replace the Screws: Schritt 17, Bild 1 von 1
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  18. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Route the Display Cable: Schritt 18, Bild 1 von 1
    • Route the display cable through the routing guides on the computer base.
  19. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Adhering the Display Cable: Schritt 19, Bild 1 von 1
    • Adhere the display cable and the camera cable to the computer base.
  20. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Connect the Display Cable: Schritt 20, Bild 1 von 1
    • Connect the display cable to the system board.
  21. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Align the Screw Hole: Schritt 21, Bild 1 von 1
    • Align the screw hole on display-cable bracket with the screw hole on the computer base.
  22. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Replace the Screw: Schritt 22, Bild 1 von 1
    • Replace the screw (M3x3) that secures the display-cable bracket to the computer base.
  23. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Route the Antenna Cables: Schritt 23, Bild 1 von 1
    • Route the antenna cables through the routing guides on the computer base.
  24. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Adhering the Camera Cable: Schritt 24, Bild 1 von 1
    • Adhere the camera cable to the computer base.
  25. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Connecting the Camera Cable: Schritt 25, Bild 1 von 1
    • Connect the camera cable to the system board.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Terrence15
79.034 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
2 Kommentare
i bought the version with the tn panel, is there a list of compatible ips panels for this particular model? thanks
michael gunawan - Antwort
Hello, I bought an IPS version around a year ago but in that time a number of things happened, The computer goes to sleep without the lid being down, so i changed the setting to “Do nothing” when i closed the lid. As you expect it did not help, insead of going to sleep the display goes black, Also my ASDFJKL keys dont work, they work somethimes but im typing on a wired keyboard because of it. I NEED HELP PLEASE HELP
Dereck Scott - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 3,047
