Zum Hauptinhalt wechseln
Dell Inspiron 15 M5030 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15 M5030 Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard drive to the base of the computer.
  2. Dell Inspiron 15 M5030 Hard Drive Replacement, Sliding the Hard Drive: Schritt 2, Bild 1 von 1
    • Slide the hard drive away from the hard-drive connector on the system board.
  3. Dell Inspiron 15 M5030 Hard Drive Replacement, Lifting the Hard Drive: Schritt 3, Bild 1 von 1
    • Lift the hard drive out of the hard-drive bay.
  4. Dell Inspiron 15 M5030 Hard Drive Replacement, Placing the Hard Drive: Schritt 4, Bild 1 von 1
    • Place the NEW hard drive in the hard-drive bay and push the hard drive towards the connector until it is fully seated.
  5. Dell Inspiron 15 M5030 Hard Drive Replacement, Replace the Screws: Schritt 5, Bild 1 von 1
    • Turn the computer over and replace the two screws that secure the hard- drive to the base of the computer.
Ziellinie
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 150
