Zum Hauptinhalt wechseln
Dell Inspiron 15 N5040 Battery Replacement
  1. Dell Inspiron 15 N5040 Battery Replacement, Turn off the Computer: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn off the computer and turn it over.
  2. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery Latch: Schritt 2, Bild 1 von 1
    • Slide the battery lock latch to the unlock position until it clicks into place.
  3. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Latch: Schritt 3, Bild 1 von 1
    • Slide and hold the battery release latch in the unlock position.
  4. Dell Inspiron 15 N5040 Battery Replacement, Removing the Battery: Schritt 4, Bild 1 von 1
    • Slide and lift the battery out of the battery bay.
  5. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery: Schritt 5, Bild 1 von 1
    • Slide the NEW battery into the battery bay until it clicks into place.
  6. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery Latch: Schritt 6, Bild 1 von 1
    • Slide the battery lock latch to the lock position.
Ziellinie
Terrence15
79.522 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 309
