Was du brauchst
Close the laptop and place it so that the back of the screen is lying flat on your work surface.
Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
Lift the battery at an angle using your fingertips and remove it from the laptop.
Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
You can now slide the optical disk drive out of the computer.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
