Zum Hauptinhalt wechseln
Dell Inspiron 15 Ram (Memory Module) Replacement
Was du brauchst
  1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Ram (Memory Module) Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): Schritt 3, Bild 1 von 3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): Schritt 3, Bild 2 von 3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): Schritt 3, Bild 3 von 3
    • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
    • Using the plastic opening tool, pry the base cover from the base.
    • Slide the base cover towards you and remove it from the base. Put it aside.
  4. Dell Inspiron 15 Ram (Memory Module) Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 15 Ram (Memory Module) Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 15 Ram (Memory Module) Replacement: Schritt 4, Bild 3 von 3
    • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
    • Slide the memory module out of its slot and lift it out of the laptop base.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 5-8, Landers Spring 2016 Mitglied von UMass Dartmouth, Team 5-8, Landers Spring 2016
UMASSD-LANDERS-S16S5G8
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 48
Insgesamt: 6,845
