Zum Hauptinhalt wechseln
Dell Inspiron 15-3521 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: Schritt 1, Bild 3 von 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: Schritt 2, Bild 1 von 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: Schritt 2, Bild 2 von 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: Schritt 2, Bild 3 von 3
    • Loosen the two screws attaching the access door to the laptop body.
    • Using a spudger, pry open the access door from the laptop.
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: Schritt 3, Bild 1 von 3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: Schritt 3, Bild 2 von 3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: Schritt 3, Bild 3 von 3
    • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
    • Loosen and remove these screws using a phillips head screw driver PH0.
    • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
  4. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: Schritt 4, Bild 1 von 3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: Schritt 4, Bild 2 von 3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: Schritt 4, Bild 3 von 3
    • Identify the Hard Drive caddy screws, one on each side of the hard drive casing.
    • Remove these screws using a phillips head PH0 screwdriver.
    • Now, with a new hard drive, attach the caddy/casing using the same screws removed from the old hard drive.
Abschluss
28 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrew Dippre
2.902 Reputation
7 Anleitungen geschrieben
Clemson, Team 3-1, Benson Fall 2014 Mitglied von Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 25
Letzte 30 Tage: 75
Insgesamt: 32,844
