Zum Hauptinhalt wechseln
Dell Inspiron 15-3542 LCD Screen Replacement
Was du brauchst
  1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 3 von 3
    • Power off the laptop.
    • Flip the laptop over so the bottom is facing up.
    • Slide the right button to the unlock symbol.
    • Slide the left button to the other unlock symbol.
    • While holding the left button, use your right finger to raise the battery up from the laptop.
  2. Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over so the top is facing up and open the laptop.
    • Using both hands, unsnap the tabs around the perimeter of the bezel and remove it from the laptop.
  3. Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the four screws from the corners of the LCD using a Phillips screwdriver.
    • Lift the screen up and place it on the keyboard.
  4. Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 15-3542 LCD Screen Replacement: Schritt 4, Bild 3 von 3
    • Gently peel off the yellow clear tape securing the video connector.
    • Use an opening tool to flip open the video connector bracket.
    • Make sure not to force the video cable when removing it from the connector bracket.
    • Disconnect the cable from the LCD screen and remove the LCD from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Najeemdeen Lamidi
130 Reputation
1 Anleitung geschrieben
York University, Team S3-G48, Melo-Thaiss Fall 2020 Mitglied von York University, Team S3-G48, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G48
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 14
Letzten 30 Tage: 43
Insgesamt: 803
