Zum Hauptinhalt wechseln
Dell Inspiron 15-5547 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15-5547 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Flip the laptop on its top so that the back is facing up as seen in the picture.
    • Using a Phillips #0 screwdriver, remove the two screws.
  2. Dell Inspiron 15-5547 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Using an iFixit Opening Tool, pry open the back panel through the small notch.
  3. Dell Inspiron 15-5547 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the four screws securing the hard drive.
  4. Dell Inspiron 15-5547 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Lift the hard drive out of the dock and unplug from the motherboard.
    • Be careful so as to not damage the cable.
  5. Dell Inspiron 15-5547 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips #0 screwdriver, unscrew the four screws located on the side of the chassis to free the hard drive from the bracket.
    • Remove the hard drive from the bracket.
Abschluss
Nicholas Nafziger
266 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G2, Harley Fall 2019 Mitglied von IUPUI, Team S1-G2, Harley Fall 2019
IUPUI-HARLEY-F19S1G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 1,253
