Zum Hauptinhalt wechseln
Dell Inspiron 15-5548 RAM Replacement
Was du brauchst
  1. Dell Inspiron 15-5548 RAM Replacement, RAM: Schritt 1, Bild 1 von 3 Dell Inspiron 15-5548 RAM Replacement, RAM: Schritt 1, Bild 2 von 3 Dell Inspiron 15-5548 RAM Replacement, RAM: Schritt 1, Bild 3 von 3
    • Unplug and power off the laptop.
    • Turn the laptop over so that the grill for the fans is at the top. Locate the two screws above the grill.
    • Remove the screws with a Phillips 00 Screwdriver.
  2. Dell Inspiron 15-5548 RAM Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-5548 RAM Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to lift up on the casing and remove it from the laptop.
  3. Dell Inspiron 15-5548 RAM Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 15-5548 RAM Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 15-5548 RAM Replacement: Schritt 3, Bild 3 von 3
    • Locate the RAM sticks on the left side of the device.
    • On both ends of the RAM stick, pull the metal tabs away from each other.
    • The RAM stick will pop up. Gently pull the RAM stick out.
Abschluss
Jacob Cotton
101 Reputation
1 Anleitung geschrieben
Ein Kommentar
Hi Mr Cotton. Greetings. I have a Dell Inspiron 5548. Can I replace the present 8GB ram with 32GB in any type of DDR4 laptop ram?
Please respond to lucien395@gmail.com
Thank you
George Livingstone - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 815
