Was du brauchst
Slide the battery release switch away from the lock symbol towards the “unlock” position.
Rotate the battery outward by lifting the bottom lip that pops out.
Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Keyboard
Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
CD-Drive
Flip the computer over, *screen down* and unscrew the 1 screw in the middle located below the battery with a J0 bit tipped screwdriver.
Next using the J0 bit tipped screwdriver unscrew the 2 remaining screws shown in the picture.
After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer.
Eine weitere Person hat diese Anleitung absolviert.
