Zum Hauptinhalt wechseln
Dell Inspiron 15-5558 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15-5558 Display Assembly Replacement, Note the Antenna Cable: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 15-5558 Display Assembly Replacement, Disconnecting the Display Cable: Schritt 2, Bild 1 von 2 Dell Inspiron 15-5558 Display Assembly Replacement, Disconnecting the Display Cable: Schritt 2, Bild 2 von 2
    • Lift the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15-5558 Display Assembly Replacement, Note the Display Cable: Schritt 3, Bild 1 von 1
    • Note the display cable routing and remove the cable from its routing guides.
  4. Dell Inspiron 15-5558 Display Assembly Replacement, Turn the Computer Over: Schritt 4, Bild 1 von 1
    • Turn the computer over.
    • Open the display at an angle of 90 degrees.
  5. Dell Inspiron 15-5558 Display Assembly Replacement, Placing the Computer: Schritt 5, Bild 1 von 1
    • Place the computer on the edge of the table so that the palm-rest assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  6. Dell Inspiron 15-5558 Display Assembly Replacement, Remove the Screws: Schritt 6, Bild 1 von 1
    • Remove the screws that secure the display hinges to the palm-rest assembly.
  7. Dell Inspiron 15-5558 Display Assembly Replacement, Lifting the Display Assembly: Schritt 7, Bild 1 von 1
    • Lift the display assembly off the palm-rest assembly.
  8. Dell Inspiron 15-5558 Display Assembly Replacement, Placing the Palm Rest Assembly: Schritt 8, Bild 1 von 1
    • Place the palm-rest assembly at the edge of the table with the coin-cell battery facing away from the edge.
  9. Dell Inspiron 15-5558 Display Assembly Replacement, Align the Screw Holes: Schritt 9, Bild 1 von 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  10. Dell Inspiron 15-5558 Display Assembly Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 15-5558 Display Assembly Replacement, Route the Display Cable: Schritt 11, Bild 1 von 1
    • Close the display and turn the computer over.
    • Route the display cable through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 15-5558 Display Assembly Replacement, Slide the Display Cable: Schritt 12, Bild 1 von 1
    • Slide the display cable to the connector and press down on the latch to connect the display cable to the system board.
  13. Dell Inspiron 15-5558 Display Assembly Replacement, Routing the Antenna Cable: Schritt 13, Bild 1 von 1
    • Route the antenna cable through the routing guides on the palm-rest assembly.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,851
