Zum Hauptinhalt wechseln
Dell Inspiron 15-5558 RAM Replacement
Was du brauchst
  1. Dell Inspiron 15-5558 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 RAM Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 15-5558 RAM Replacement: Schritt 3, Bild 2 von 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 RAM Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Dell Inspiron 15-5558 RAM Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Dell Inspiron 15-5558 RAM Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 RAM Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 15-5558 RAM Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 15-5558 RAM Replacement: Schritt 5, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
  6. Dell Inspiron 15-5558 RAM Replacement, RAM: Schritt 6, Bild 1 von 3 Dell Inspiron 15-5558 RAM Replacement, RAM: Schritt 6, Bild 2 von 3 Dell Inspiron 15-5558 RAM Replacement, RAM: Schritt 6, Bild 3 von 3
    • Locate the two RAM cards.
    • Using your finger, pull the two small pins back from the RAM causing it to pop up.
  7. Dell Inspiron 15-5558 RAM Replacement: Schritt 7, Bild 1 von 1
    • Once popped up, pull the ram out.
Abschluss
Adam Lourenco
775 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G4, Bailey Fall 2017
UMASSD-BAILEY-F17S3G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 26
Insgesamt: 1,396
