Einleitung
If your device screen breaks, you might need to replace it. The screen is the part of the device when images are displayed. This guide shows you how to replace a broken or faulty screen
Was du brauchst
Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
Open device so it is at least opened at a 90 degree angle.
Wedge a spudger between the screen and the plastic frame.
Push in the spudger and push down to pop the frame from the pins.
Repeat around the whole frame.
Once all the pins are off, remove the frame by pulling it away from the screen.
Using a Phillips #0 screwdriver, unscrew the four 3mm screws holding the screen in place.
Push the spudger behind the screen and push down to remove the screen.
Pull the tape connecting the screen up with your fingers and pull the securing bar up with it.
Disconnect the securing bar to remove the screen.
6 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
How many pins is the screen connector? 30? 40?
