Einleitung
Before you begin, you will need a Phillips #1 screwdriver and a black nylon spudger to complete the CD Drive removal. You will also need to remove the battery of your device before you begin.
Was du brauchst
Use the Philips #1 to remove the two (2) 2.5x8mm screws that anchor the CD Drive.
Place the spudger at the spot indicated by the red circle.
Use your hand to pull the CD drive out while using the spudger as leverage to push the CD drive out.
2 weitere Personen haben diese Anleitung absolviert.
