Zum Hauptinhalt wechseln
Dell Inspiron 15-5559 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: Schritt 1, Bild 1 von 2 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Inspiron 15-5559 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-5559 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
    Frag FixBot
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 3 von 3
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
    Frag FixBot
  4. Dell Inspiron 15-5559 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
    Frag FixBot
  5. Dell Inspiron 15-5559 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15-5559 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Baylor, Team S5-G5, Williams Spring 2018 Mitglied von Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare zur Anleitung
The blue part came off is that important?
walterandradeconde - Antwort Teilen
can i put this in a harddrive enclosure?
chiggly 123 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 6,039
