Zum Hauptinhalt wechseln
Dell Inspiron 15-5565 Coin Cell Battery Replacement
Was du brauchst
  1. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Coin Cell Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 15-5565 Coin Cell Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 15-5565 Coin Cell Battery Replacement: Schritt 2, Bild 3 von 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Back Cover: Schritt 3, Bild 1 von 2 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Coin Cell Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-5565 Coin Cell Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: Schritt 5, Bild 1 von 3 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: Schritt 5, Bild 2 von 3 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: Schritt 5, Bild 3 von 3
    • Remove the coin-cell battery by carefully pulling the plug from the slot.
    • The coin-cell battery is simply plugged into the circuitry. No screws or tools are needed.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 33
Insgesamt: 295
