Einleitung
Removing the back cover is a fundamental step for cleaning, replacing, or repairing many other components inside the laptop. That’s why this will serve as a pre-requisite task for most of the replacement guides of the Dell Inspiron 15-5567. You will only need a Philips #0 screwdriver and the blue plastic opening tool to complete this guide.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
Remove two M2x4mm screws using the same screwdriver.
Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
Slide the rest of it out with your hand.
Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
Grab the corners of the cover firmly and lift it up.
2 weitere Nutzer haben diese Anleitung absolviert.
