Zum Hauptinhalt wechseln
Dell Inspiron 15-5567 Battery Replacement
Was du brauchst
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 15-5567 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 15-5567 Battery Replacement: Schritt 2, Bild 3 von 3
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 15-5567 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-5567 Battery Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
  5. Dell Inspiron 15-5567 Battery Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15-5567 Battery Replacement: Schritt 5, Bild 2 von 2
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Saaed Chaudhry
478 Reputation
2 Anleitungen geschrieben
York University, Team S1-G8, Melo-Thaiss Summer 2021 Mitglied von York University, Team S1-G8, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G8
1 Mitglied
Ein Kommentar
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 68
Insgesamt: 8,367
