Zum Hauptinhalt wechseln
Dell Inspiron 15-5567 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15-5567 Display Assembly Replacement, Remove the Display Cable: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 15-5567 Display Assembly Replacement, Note the Display Cable Routing: Schritt 2, Bild 1 von 1
    • Note the display cable routing and remove the cable from its routing guides.
  3. Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Latch: Schritt 3, Bild 1 von 2 Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Latch: Schritt 3, Bild 2 von 2
    • Lift the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 15-5567 Display Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 15-5567 Display Assembly Replacement, Open the Display Hinges: Schritt 5, Bild 1 von 1
    • Open the display hinges.
  6. Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Palm Rest: Schritt 6, Bild 1 von 1
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 15-5567 Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 1 von 1
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Dell Inspiron 15-5567 Display Assembly Replacement, Press the Display Hinges: Schritt 8, Bild 1 von 1
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Dell Inspiron 15-5567 Display Assembly Replacement, Replace the Screws: Schritt 9, Bild 1 von 1
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Dell Inspiron 15-5567 Display Assembly Replacement, Routing the Display Cable: Schritt 10, Bild 1 von 1
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Dell Inspiron 15-5567 Display Assembly Replacement, Sliding the Display Cable: Schritt 11, Bild 1 von 1
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
Terrence15
79.522 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
Ein Kommentar
Nice, is the part available?
gideon onwuka - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 2,178
