Einleitung
Because the model device does not have a hard drive, this is not a replacement guide, but merely a prerequisite guide for other removal guides.
Was du brauchst
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
The model device did not come with a hard drive. However, you will need to remove the hard drive to proceed. Please remove the hard drive following the steps on page 16 of the official Dell Inspiron 15-7537 manual.
6 weitere Personen haben diese Anleitung absolviert.
