Einleitung
Use this guide to replace the keyboard if you have determined your keyboard issues may be resolved by replacing the keyboard.
Was du brauchst
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
Flip over the computer and open the display as far as it can go.
Use the spudger to remove the keyboard from the palm assembly.
Gently flip over the keyboard and place it on the palm rest assembly.
Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Thanks It’s Useful
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
