Zum Hauptinhalt wechseln
Dell Inspiron 15-7537 Wireless Card Replacement
Was du brauchst
  1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: Schritt 1, Bild 1 von 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: Schritt 4, Bild 1 von 2 Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: Schritt 4, Bild 2 von 2
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  5. Dell Inspiron 15-7537 Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the two antennas (one black and one white) from the wireless card.
  6. Dell Inspiron 15-7537 Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 18-2, Maness Winter 2015 Mitglied von Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 3,523
