Zum Hauptinhalt wechseln
Dell Inspiron 15-7547 CPU Fan Replacement
Was du brauchst
  1. Dell Inspiron 15-7547 CPU Fan Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 CPU Fan Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 CPU Fan Replacement, CPU Fan: Schritt 3, Bild 1 von 2 Dell Inspiron 15-7547 CPU Fan Replacement, CPU Fan: Schritt 3, Bild 2 von 2
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  4. Dell Inspiron 15-7547 CPU Fan Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-7547 CPU Fan Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  5. Dell Inspiron 15-7547 CPU Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift the fan out of the chassis.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 554
