Zum Hauptinhalt wechseln
Dell Inspiron 15-7547 LCD Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15-7547 LCD Assembly Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: Schritt 3, Bild 1 von 2 Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: Schritt 3, Bild 2 von 2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 4, Bild 2 von 2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  6. Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: Schritt 6, Bild 1 von 3 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: Schritt 6, Bild 2 von 3 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: Schritt 6, Bild 3 von 3
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  7. Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 7, Bild 3 von 3
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  8. Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 8, Bild 1 von 3 Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 8, Bild 2 von 3 Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 8, Bild 3 von 3
    • Raise the left and right hinges.
  9. Dell Inspiron 15-7547 LCD Assembly Replacement: Schritt 9, Bild 1 von 1
    • Remove the LCD display assembly from the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 761
