Einleitung
Use this guide to remove the motherboard on a Dell Inspiron 15-7547.
Was du brauchst
Close the display and flip the laptop on its back.
Loosen the ten 5.0 mm-long Phillips #0 screws.
The four screws marked with orange will remain captive to the cover.
Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
Remove the battery.
Remove the Wifi-Card from its socket by pulling away and up from the connector.
Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
Remove the two 5.0 mm-long Philips #0 screws from the fan.
The screw marked in orange will remain captive to the fan.
Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
Release the clamps on each side of the RAM sticks by pushing away from the center.
Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
Unlatch the ribbon cable by pulling the white release up.
Hold the blue flap and pull to unplug the cable.
Unlatch black release on the ribbon cable.
Hold the blue flap to unplug the cable.
Unlatch the ribbon cable by pulling the black release up.
Hold the flap and unplug the cable.
Hold the blue flap and unplug the cable.
Eine weitere Person hat diese Anleitung absolviert.
