Zum Hauptinhalt wechseln
Dell Inspiron 15-7547 WiFi Card Replacement
Was du brauchst
  1. Dell Inspiron 15-7547 WiFi Card Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 WiFi Card Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 WiFi Card Replacement, WiFi Card: Schritt 3, Bild 1 von 2 Dell Inspiron 15-7547 WiFi Card Replacement, WiFi Card: Schritt 3, Bild 2 von 2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 WiFi Card Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-7547 WiFi Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 WiFi Card Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15-7547 WiFi Card Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
Abschluss
Claro
591 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 322
