Einleitung
This guide will walk you through how to remove the Fan in your Dell Inspiron 15-7548.
Was du brauchst
Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
To unplug the CPU fan lift the black plastic cutout next to the fan.
The connection can be removed by hand or with the plastic spudger.
Remove the two 2x3mm screws from the fan using the Phillips #1 screwdriver.
The unit may now be removed from the board.
Disconnect the unit from the motherboard.
The black and white wires need to be unplugged and removed from the tabs on the fan.
Use a pair of tweezers to unplug the wires.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
