Zum Hauptinhalt wechseln
Dell Inspiron 15-7548 Motherboard Replacement
Was du brauchst
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 2 Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-7548 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Remove the motherboard.
Abschluss
Michael Nunez
325 Reputation
2 Anleitungen geschrieben
IUPUI, Team 3-3, Beck Spring 2022 Mitglied von IUPUI, Team 3-3, Beck Spring 2022
IUPUI-BECK-S22S3G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 558
