Einleitung
Is the sound coming out of your laptop distorted or unclear? Consider using this guide to replace the speakers in your device.
Was du brauchst
Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
Untangle the wire from the plastic clips and remove the speakers from the device.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
