Zum Hauptinhalt wechseln
Dell Inspiron 15-7548 Speaker Replacement
Was du brauchst
  1. Dell Inspiron 15-7548 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 2 Dell Inspiron 15-7548 Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Speaker Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-7548 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Speaker Replacement, Battery: Schritt 3, Bild 1 von 2 Dell Inspiron 15-7548 Speaker Replacement, Battery: Schritt 3, Bild 2 von 2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Speaker Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-7548 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Remove the ribbon cable by pulling it out.
  6. Dell Inspiron 15-7548 Speaker Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 15-7548 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Remove the compression caps by using the spudger.
  7. Dell Inspiron 15-7548 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Untangle the wire from the plastic clips and remove the speakers from the device.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 837
