Einleitung
This guide is used as a precursor for the battery, SSD, and display replacement guides.
Was du brauchst
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
Use the blue, plastic opening tool to gently pry a section of the back panel open.
Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
After the clips have been disconnected, the back panel can then be easily lifted off the computer.
To reassemble your device, simply press the back panel on until all pins snap back into place and then screw the back panel back on.
3 weitere Personen haben diese Anleitung absolviert.
